help me pick my turbo kit
93hb
off 2000 civic si 3 k miles old
t3/to4e turbo
intercooler
piping
downpipe
vortech fmu
tial wastegate
310 rc injectors
holley fuel pump
hks blow off valve
hks boost gauge
all wiring and lines
will this set up be better?
or this set up?
HKS B-series turbo manifold(cast-iron)
Greddy/Mitsu Tdo4(no shaft play)
Downpipe
Spearco FMIC 26x8x3(polish)
Charge pipe/intercooler pipping
Blitz's Blow-off valve
Walbro 255lph intank fuel pump
FMU
Missing Link
VDO boost gauge
sArd's(jdm) turbo timer
Brass fittings/SS feedline/return line
i only plan to run 8psi...never any higher than that. what do you guys think?
#1 i garuntee ull boost more than that once u fell the diff in higher boost lbs :thumbsup: , and id go with the 2nd kit, that is if u were going to go wtih a kit, which i wouldnt...but that greddy td04 is that the 18g? if so thats a nice turbo for ur set up...good luck
Originally posted by 93hb@Jun 24 2003, 08:29 PM
i think its a 15g turbo
15g is faaaarrr too small for a b18b, ull atleast want an 18g...but check out maxrev's site they r pricey but nice kits
If you compare the price on our kits with our competitors, you will find that we are very reasonable. Plus our manifolds don't crack like a lot of others. ;)
