ive been fixing little things here and there on the civic, and im just not sure what in the hell to do with it. parts of me want to keep it, parts of me want to get rid of it. as some of you saw, i have an offer on the car in its current state for $6,000 USD.
so Hondaswap, what do you think the Civic is worth?
here's a parts list as of right this second:
1996 Civic Hatch - Clean title
170k miles on the chassis
3,800 miles on the engine after the rebuild
B18B1 bottom end:
Eagle Rods
JE Pistons (8.8:1)
OEM main, rod bearings
new OEM front and rear main seals
new OEM timing belt tensioner
new (<350 miles) Gates racing timing belt
vibrant performance timing belt tensioner
ACT stage 3 clutch
B16 transmission (not perfect, but it works)
MFactory LSD
GM Syncromesh - Friction Modified always used
Fresh syncrho and slide for second gear
B18b1 head:
Brian Crower dual valve springs and titanium retainers
Brian Crower "stage 2" turbo camshafts
edelbrock victor x intake manifold
RC 1000cc injectors w/resistor pack soldered in to the harness
turbo setup:
Turbonetics t04e
ramhorn manifold
TiAL 38mm wastegate
2.5" charge piping- done by me in mild steel, painted with black truck bed liner
3" downpipe, straight 3" exhaust to dynomax super turbo muffler
synapse BOV
snow performance methanol injection
mishimoto intercooler
mishimoto radiator
slim fan wired to a switch
misc:
99-00 conversion (fenders/hood are aftermarket, bumper, grille and headlights are all used OEM)
gsr fat fives in gunmetal w/falken azenis 205/50/15
99-00 hatch tail lights
led turn signals all around
fairly clean nighthawk black pearl paint
led bulbs in the gauge cluster and climate control (blue)
glowshift gauges (boost, oil pressure)
AEM wideband o2 sensor
fusebox relocated to the glovebox
battery relocated to trunk
compustar pro alarm (2way)
fuel pump cutoffs
ksport coilovers
rear disc conversion (not installed)
can have HID's if buyer so desires
armrest swap from EX coupe
vibrant shift knob
blox short throw and bushings
now for the cons:
car leaks some trans fluid, i check/fill it every couple of weeks
car uses some oil/smokes some. not sure of the cause, possibly a leaky head gasket (have replacement cometic)
overspray in door jams
one spot on the paint that needs attention (needs recleared, got through the clear coat with a POS harbor freight polisher)
post up a value on here, i need some ideas of what to ask if i do sell it..
