NotUrAverage_Si
anyone want to take a guess at how long a b20 would last on 40psi?
Originally posted by pissedoffsol@Dec 16 2003, 12:56 AM
well, as long as he doesn't unload in 3rd, and can figure out how to wire a 5-bar map sensor...... lol
asshat...
Originally posted by simplyfast@Dec 20 2003, 02:48 PM
boost is relevant to the cams your running.
Originally posted by pissedoffsol+Dec 20 2003, 09:23 PM-->simplyfast@Dec 20 2003, 02:48 PM
if you honestly think this....
i don't even fucking know what to say to you.
maybe buy a geo???
you should try LEARNING stuff, instead of makign yourself look liek a fucking idiot.
its funny though how simplyfast praises overlap...on a turbo motor, thats probally how hes running 40 psi of boost w/o it blowing up, but still making as much power as if it had 6psi.
Originally posted by simplyfast@Dec 20 2003, 10:58 PM
still stuck on this overlap thing, arent you? check this, if you run too much overlap youll wash the cylinder losing all of your boost, right? so controlling your boost can be achieved by running cams with different overlap, right? right.
Originally posted by simplyfast@Dec 20 2003, 03:48 PM
keven, you all say it cant be done, i give a way it can be done. dont forget, im the guy who will run 8 psi on an engine runnin 11:1 compression. ill just get me some fat injectors and an ecu i can tune.
si, i can build a b20 runnin 40 lbs for the rest of my life...boost is relevant to the cams your running.
yes boost is relevant to the cams. the cams have to be timed so that the boost stays in and there is adequate exhaust energy to get that turbine spinning.
and when i said that to pissedofsol he thought i was full of dookie...but when you say it, he gets on his knees. funny, really funny.
