Need someone familiar with electronics; Bergy, Cal?
Discussion in 'ECU's, Electronics, and Tuning' started by K2e2vin, Dec 17, 2009.
  1. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Alright this is concerning stepping up injector voltage in order to run saturated injectors in peak-and-hold "mode".
    Run down of the setup:
    -Megasquirt-III/MS3X(when it comes out), or Vi-PEC if they support Flex Fuel in time
    -E85/Flex fuel
    -ITB; Staged injection; 290cc/410cc Denso Injectors(CBR/RDX) running around 60psi.
    -Dry nitrous fuel comp. through primary injectors; on only when secondaries are fully online.
    And, my itemized questions:
    -I'm thinking, would it be safe to run sat. injectors at around 60v?
    -I know this will caused increased heat; but would the heat generated be easily dissipated by the fuel and could the heated fuel be beneficial(ie: the "200mpg carburetor" theory)?
    -Also, would it be beneficial to run the injectors in PnH mode; increasing response time?
    -Would this help out as far as the staged injection goes(even though there's blending, maybe reduced lag-time between switching)?
    -What about running the primaries(290cc) injectors at a lower voltage(~24v) to reduce heat since they don't see as much fuel flow/duty?
    -Can the transistors in typical PnH circuit handle the voltage and current(2N6044, LM1949 controller)? Should I upgrade?
    Edit: Can a mod please add "Injector V mod" at the beginning of the title? Thanks
