New to game
Discussion in 'Engine Building' started by 98HB, Nov 10, 2002.
  1. 98HB
    98HB Junior Member
    I have a 98 HB DX and I want to find out what should be the next step in changing some parts on my engine. I have added headers,air intake,chip,MSD wires,coil,and distributor cap, high flow exhaust, fuel rail and larger injectors. I want to get more power but I don't want Turbo or a supercharger (can't afford) so if anyone can help with ideas that have worked for you it would be great help!
    98HB :huh:
  2. phunky.buddha
    Dallas / Fort Worth, TX
    With no supercharger and turbocharger... I assume you don't want to swap the engine either if you can't afford the turbo/SC- your options are really only to bolt on a VTEC head, get higher compression pistons, upgrade your valvetrain and drop in a more aggressive camshaft like the ZEX model, then do some port & polish work. Maybe nitrous?
  3. chet
    chet Senior Member
    st petersburg, florida
    nitrous is your only other option, unfortunately a header and air intake along with msd wires aren't going to give you much power.
    unless you increase displacement or find a vtec head and intake manifold to bolt on your bottom end you'll be forced to remain slow.
  4. 98HB
    98HB Junior Member
    What type of v-tech swap should I do!. Is there a certain year or engine that I should go after. Thanks for the reply's- Hey also how hard is it to do and what kind of money am I looking at.
  5. E_SolSi
    anyway....it would be easiest for you to use the D16Y8 head it will match your OBD2 setup
  6. pissedoffsol
    a swap is going to cost you as much as a super or turbo would-- if not more.
    and you said you didin't have the money for it.....
  7. ALLJDM
    ALLJDM Senior Member
    Tampa, FLorida
    CLICK HERE
    I would suggest Chets idea. very inexpensive, easy mod.
