p28 in a d16y5??
Discussion in 'Civic and del Sol - EG and EK' started by ktyr5151, Aug 5, 2011.
  1. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    First of all here is my setup:
    D16y5 motor
    K&N CAI
    Ractive 4-2-1 Headers
    Vibrant 2.5in axleback with a hollowed out cat.
    So ive done ALOT of reading on this topic. I have a chipped p28 to my (d16y5) but in my reading i guess the vtec engagement needs to be between 2500-3000 i told the guy who did the chip to do 3700. ANYTHING on this subject would be greatly appreciated. Im just looking for options. HX enthusiasts HELP!!! What are my tuning options?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    It's a VTEC-E engine; raising the engagement point will actually kill performance.
  3. RHDism
    RHDism Right Hand Drive guru
    Why not just run the stock ECU?
    Like K2 said its VTEC "E" ... seems pointless to tune an ECU for this motor.:shrug:.
  4. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    So if i were to change the vtec engagement to say 2700 it would be alright?
  5. E_SolSi
  6. Dj211855
    Dj211855 New Member
    The best advice i can give you with your hx. Listen up:
    1. Get a ex trans
    if you really want to fool around with your car, contact delta for a cam re-grind.
    Raise the compression a bit with different piston like say pm6 or pg6, along with the cam/cam gear, ex trans. You'll have a fun daily driver.
    If you don't want to do all that just replace the trans.
  7. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    I was already thinking of getting the ex tranny. About how much generally do you think it would cost to replace a tranny?
  8. Dj211855
    Dj211855 New Member
    I have no clue of how much it would cost around your area. IF i'm around you I could do it for a fair price.
  9. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Where are you located?
  10. Dj211855
    Dj211855 New Member
    Im far from you. Southern california.
  11. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    I contacted my mechanic and he gave me an estimate of 300-350. How does that sound to everuyone for a price?
  12. Dj211855
    Dj211855 New Member
    you need a transmission? 350 wow. I normally do it for 200 on civics.
  13. K2e2vin
    Raleigh, NC
    That sounds like typical "book" price.
  14. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Come to Vermont? Hah ;)
  15. Dj211855
    Dj211855 New Member
    I read your first post. Do you a ecu conversion harness?
  16. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Yes i do. I just ordered it last friday and it should be her by sometime this week.
  17. Dj211855
    Dj211855 New Member
    The y5 won't like the p28 maps...
    I hope whoever did your chip have any clue that a y5 uses 190cc injectors and I hope it was change. As far as vtec engagement, I set mine to 2800rpm.
  18. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    Im pretty sure that it was set to the 240 cc injectors. I had no clue that they were the 190cc
  19. Dj211855
    Dj211855 New Member
    they are 190cc, obd2 ex 240ccc, z6 ex 240cc. If you need injectors let me know or have him adjust it to 190.
    Also obd2a to obd1 jumper is not exactly made for hx with 5 wires primary and 4 wires secondary. Make sure you use the 4wires secondary, you going to have to jump the wire to secondary.
    You be glad I'm helping you out:)
  20. ktyr5151
    ktyr5151 New Member
    Springfield, VT
    I might need those injectors. I'm not exactly sure what you mean by the harness thing. I'm not familiar with that.
