Please help with new high flow cat. please guys
Discussion in 'Accord' started by 91accordwithwork, Aug 22, 2008.
Thread Status:
Not open for further replies.
  1. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
    Hey all and please help with me a quick questions
    ok so i bought a new (very nice) high flow cat from ebay and i have a question.
    -my old cat is so corroded and nasy so it will not unbolt even with rust eater or anyhting with that. the bolts are rounded.... and the wholel thigns rusted and nasty/.......
    ok so i want it off , so that i can screw the new one on u no? so i am asking for and tips or ways i can get the old one off , i have a saw's all and i might try to chop the bolts off but please any way to get this thing off!
    thanks!!!!!!!1
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    saws all or torch
  3. 91accordwithwork
    Wauwatosa WI
    yah whats the best way to get it off with the saw, liek where to cut u na? the end of it?
  4. AHHVTEC
    Alabama
    i say in the middle where the flange comes together
  5. 91accordwithwork
    Wauwatosa WI
    so try to like cut at each end of the old cat? and then it should come right off, if i cut through tthe bolts that way it will come off
    but any other way?
  6. AHHVTEC
    Alabama
    not that i know of
  7. 91accordwithwork
    Wauwatosa WI
    thanks so much tech
    ill do my best do u think i should be able to get it tho????
  8. AHHVTEC
    Alabama
    naa not really lol, id take it to a shop and put it on a rack torch it off, but good luck trying to find a shop that will mess with the cat. if it was alabama it would be easy
  9. efhondakid
    Akron-Canton, Ohio
    Chop it off, get some new bolts and bolt up the new one, done.
  10. awptickes
    MD
    You're still having problems with your car, and now you're messing with the exhaust system, a modification that will probably need your engine to be tuned.
    Srsly, fix, then play.
  11. efhondakid
    Akron-Canton, Ohio
    Its been proven removing your catalytic converter will only net you about 2-3 more whp on the dyno.
  12. awptickes
    MD
    OOps, nevermind. Different noob with an Accord.
  13. efhondakid
    Akron-Canton, Ohio
    What? No this is our boy, the one that couldn't figure out what to do with his oil cap once he got his VC off.
  14. awptickes
    MD
    I stand corrected.
    OP: Go to an exhaust shop.
  15. nootrac22
    exeter pa
    just don't forget the new gaskets
  16. George777
    George777 ^^ Likes Bewbies
    With your mom
    If it were my car, I would take it to a shop like they are saying. Have the shop chop it off, where they can also weld new flanges on there. Then you can bolt it back in there. By not welding the cat itself in there, it will allow you the opportunity to change it out in the future.
  17. 91accordwithwork
    Wauwatosa WI
    the flanges aare already goos its just the cat and its bolts are so rusted i cant seem to unscrew them
    but im going to try and saw all the heads of the bolts off
  18. George777
    With your mom
    How are the flanges already gone if the bolts are still connected? Am I missing something here?
  19. 91accordwithwork
    Wauwatosa WI
    o srry typo i meant to say the flanges are good but i said goos accident
    yah theere goos just need to get those bolts off... thinking of ways how
  20. BrutalB83
    Rochester Hills, MI
    Do you have a breaker bar? If not, go buy one. Or, if you're cheap, you can just put a long piece of pipe over your ratchet. Try soaking the bolts down again with WD-40 or PB-Blaster or whatever you're using, and then crank on them with the breaker bar. You might be surprised what happens...
Thread Status:
