There are many different brands other than RC engineering, but yes, you defidently have to upgrade your injectors. It depends on how much hp you plan to make.
obd2 harnesses need the rc plugs. they are basically obd1 copies. so, if you used an obd2 wire harness, you will need to pick up the rc injector plugs (or cut them off an obd1 harness)
