shipping monitor
Discussion in 'Members' Lounge' started by Briansol, May 7, 2009.
  1. Briansol
    I got my shipping label today, so i need to send my 30" back to samsung for service.
    I have the orig box, but i do not have the packing materials. Mainly, it came with foam "shoulders" where the monitor sat 'flaoting' in the center of the box held in on just the side.
    I don't think peanuts is going to suffice.
    ideas?
  2. Briansol
    i need to come up with something like this:
  3. invisibledemon
    Tn
    shouldnt be hard to do, lowes or home depot should have some cheap packaging supplies like that.
  4. Drake
    Drake Well-Known Member VIP
    Pick up some styrofoam blocks or that plastic carbonate shit that is used as a styrofoam replacement and just cut it to form.
    Edit:
    Hit up your local UPS Store and see if they have any supply's.
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    that and buy a pack off balloons
  6. E_SolSi
    wrap the shit out of the 2 ends with enough bubble wrap to hold the center away from the box
  7. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    Use anything you can in the corners to create that same floating function and then fill in the voids with the packing peanuts. Wrap the monitor first with plastic.
  8. TurboMirage
    i wrap the whole thing with a shit ton layers of bubble-wrap, and stick it in the box. fill the voids with peanuts.
    yes, i've done this. its safe.
  9. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I usually fold cardboard pieces to push the item away from the actual box. Acts like a shock absorber. Of course, foam blocks would help too and crumbled up newspaper to help keep the item from moving around.
    Also, a LOT of bubble wrap works too. I wouldn't really recommend peanuts unless the item is much smaller than the box.
  10. jamesA
    This is exactly what I was going to say.
  11. awptickes
    MD
  12. DarkHand
    DarkHand Senior Member VIP
    Chicago, IL
    Many moons ago I sent in my monstrous 4x cd-r burner for an RMA, and was so scared of it getting damaged further in shipping (I've worked at UPS, I know what goes on in there) that I built a wooden frame and used 8 springs to suspend the burner inside it. No matter which way you bumped it the burner would just wiggle around inside. They actually put it back into the contraption when they sent it back to me. Too bad it died again a few months later. :mad:
  13. awptickes
    MD
    Wow. Pics?
  14. jamesA
    That sounds awesome, receiving that would have made my day.
  15. DarkHand
    Chicago, IL
    I wish I had some, it was maybe in 1998-99. :(
  16. nootrac22
    exeter pa
    spray foam!!!!!!!!!!!!
  17. phunky.buddha
    Dallas / Fort Worth, TX
    Newspaper. They're not going to ship it back to you in that box anyway, or even ship you back the same panel. They don't want to keep it either.
  18. Briansol
    from what i can tell, they are going to try to fix it. they don't make this model any more, so i don't think they have stock lying around of it.
  19. Drake
    Could end up getting a new equivalent model then. That would be pretty sweet.
  20. klyph
    klyph Dismember VIP
    North Pole, AK
    Word, wrap it in a few layers of saran wrap, then in an oversive box, spray foam the corners so that it's suspended within the box. Add packing peanuts or those plastic air bags if you're paranoid. Cheapest way IMO.
