Tail lights between years???
Discussion in 'Civic and CRX - EF' started by khrisb, May 6, 2008.
  1. khrisb
    khrisb ******
    Are the tail lights interchangeable between years of civics and/or crxs? I have an 89 hatch with a cracked tail light. The junk yard has a 90 tail light. They say it won't fit. I'm skeptical. Can you crank a sedan tail light or crx tail light into the hole?
  2. SlushboxTeggy
    NJ to MA to CA
    Any of the same generation, same model should fit, but make sure it's from the same body style (hatch, coupe, sedan) because many differed between styles.
  3. khrisb
    khrisb ******
    so 91 hatch tail lights will fit my 89 hatch?
  4. SlushboxTeggy
    NJ to MA to CA
    They should. That's not the generation I'm familiar with, but I'm pretty sure.
  5. GlassHeadlights
    Calgary, AB
    physically theyre the same but the outside look is different.the tail lights have to from a hatch, not a crx and not a sedan. the 90-91 lights have another brake light hole rather than just 1 in the 88-89 lights.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    No!
    They're different; different shape and bolt pattern. I know this because I physically tried.
  7. GlassHeadlights
    Calgary, AB
    wel then how is it possible that i have 89 hatch taillights on my 90 hatch?
  8. K2e2vin
    Raleigh, NC
    I was talking about CRX/Sedan taillights on a Civic hatchback. For the same cars, 88-91 will fit.
  9. BrokenRex
    BrokenRex New Member
    they already posted to keep your body style the same. i have 90 rex tails on my 89 rex too, but that doesn't apply to what he said. if you have a hatch, 88-91 lights will work. if you've got a rex, 88-91 will work. sedans i'm not sure about, but you have a hatch, so you shouldn't care about them anyway.
  10. khrisb
    khrisb ******
    well i was able to find an 89 tail light, the junkyard still swears only 88-89 and 90-91 will fit those models. I guess I'll know for future reference.
    thanks all
  11. Periculum
    Periculum Senior Member
    Martinez, GA
    I've seen plenty notes saying you can't interchange the different years on a CRX, but I've been back and forth between the two sets a couple times.
    I'm sure you can't change between body styles, but I don't think the year difference should stop you.
