vtec controller wiring
Discussion in 'ECU's, Electronics, and Tuning' started by HATCHET_HONDA, Dec 17, 2007.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    ive been looking into getting a vtec controller for my d15b..i have no idea how to install one and i dunno if they come with instructions. also ive seen them where they say you dont have to tap into the ecu. any help would be great..thanks
  2. lsvtec300
    lsvtec300 Junior Member
    los angeles
    if you buy the apexi vafc it will come with installation guide but u do have to do some cuting and saudering by the ecu to make it work
  3. HATCHET_HONDA
    hobart, indiana
    from what ive searched the apexi seems to be the best route. and i did find the install guide online although hard to read.. ever install one? is it splice a couple wires and presto...controllin vtec?
  4. lsvtec300
    los angeles
    i did one long time ago but it wasnt easy and it never ran good if i was u i would gave it to a professional, save ur self from the headaches
  5. HATCHET_HONDA
    hobart, indiana
    damn....was the install that sucked more or tuning it to run the right way?
  6. lsvtec300
    los angeles
  7. HATCHET_HONDA
    hobart, indiana
    damn..damn..maybe ill just get the buddy club controller
  8. ls ef
    ls ef New Member
    I heard that they aen't hard t tune, but I have never used one myself. As for wiring it shouldn't be that bad. I know some people make jumper harness's so that it just comes pre-wired for the vafc.
  9. HATCHET_HONDA
    hobart, indiana
    ill have to look into that one..thanks for the input
  10. onehavickman
    onehavickman New Member
    Got one on my 95 civic ex on a JDM B18c. It was on it when I got the car....another friend of mine doesn't have one and I always stay 3 car lengths ahead....problem is it was tuned by some pros for racing...I'm a techie so I downloaded the manual....installation is easy....tuning isn't...give me a couple more days and I should have it down and i'll let you know...;)
    1995 Honda Civic Ex Coupe
    JDM B18c Swap type R
    Suspension:
    Coilovers
    Front and Back Camber Kit
    Neuspeed Front Upper Strut Bar
    Neuspeed Rear Lower STrut Bar
    Exterior:
    17" ADR M-Sport Rims (Example Picture Below)
    (Not the rims mounted on the Vehicle in pics)
    Rear Fog Light
    Wings West Mugen Style Side Skirts
    Engine:
    JDM B18c
    DC Header
    ACT Street Strip Clutch With Heavy Duty Pressure Plate
    MSD Ignition Wires
    Short Ram Intake
    Apexi World Sport II Exhaust
    Greddy Oil Catch Can
    Rage Racing Cam Gears
    New HeadGasket (Changed when did the swap to be safe)
    New Timing Belt (Changed when did the swap to be safe)
    New Water Pump (Changed when did the swap to be safe)
    New Timing Belt Tensioner (Changed when did the swap to be safe)
    New Fuel Filter (Changed when did the swap to be safe)
    Skunk2 Vtec Solenoid Cover
    Skunk2 Pro Series Intake Manifold
  11. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    The VAFC's can be installed as a piggy-back on the ecu WITHOUT cutting wires... If my memory serves me right, www.boomslang.com sells the conversion harness' to install the VAFC without any cutting or wiring.
  12. HATCHET_HONDA
    hobart, indiana
    cool...thanks for the references...
