How is it on the highway? My Cherry Bomb Turbo is great around town, but has a serious drone 60-90mph.+1 dyno super turbo i got 1 on my hatch looks stock and super quite
\yes but it sounds nasttttttttyyyyyyyyyyyyyyyyyyyyyyyyy^^^Bidd-er-raspy..raspy..raspy!! Far from quiet for sure but will get you good flow results.
exactly... on my turbo set up i had 3 in open down pipe and now im jus all motor its 2 1/2I don't like anything over 2-1/4" but sounds like a lot of guys go 2-1/2"
3" is crazy unless you are turbo....lose power with 3" in an all motor set up
wats his set up tho???? cuz basemodel k's are super gay in my opion jsu like a stock b16....... my buddy has a stock k24 (type s) swap in his ek hatch and spanked my ls vtec turbo on 6 psi......havent had any problems so far. got a bro thats using the same setup in a k swapped eg hatch. still dips out like a mofo
You wont run into problems but you do not have enough back pressure. Turbo wants the least amount of resistance (back pressure) but all motor set ups needs a balance of flow and back pressure for OPTIMUM performance. So you are losing power over what you could be producing. Same goes for your friend's k swaphavent had any problems so far. got a bro thats using the same setup in a k swapped eg hatch. still dips out like a mofo
its a type swats his set up tho???? cuz basemodel k's are super gay in my opion jsu like a stock b16....... my buddy has a stock k24 (type s) swap in his ek hatch and spanked my ls vtec turbo on 6 psi......
