10sec.hatch
got my motor back yesterday and its finally time to go to the track after 3 weeks of being down from bending a rod
25psi took its toll on the rod and this was in a motor that was put in just for the hell of it while my other motor was being built now i have crower rodsbent a stock rod...what kinda rods did you replace em with?
wow25psi took its toll on the rod and this was in a motor that was put in just for the hell of it while my other motor was being built now i have crower rods
no their benson sleeves 84.5mm boreare those stock sleeves? with no block guard?
its called patience and taking your time its a tight fit real tightnice!
i always wondered... how the hell do bolt the manifold to the head with all that pipe in the way?
so no cams.stock gsr head
the whole top end is bone stock -the manifold and injectors. and it still retains the stock throttle body for now and the skunk manifold is not ported i think the main reason for the power output is due to the intercooler its nice having the iat's at 75 degrees going into the motorNice times man and the skunk2 man is it ported and if not the skunk2 manifold took all that power wow most poeple just use the jg. What size throttle body are you running? Also what cams are you running sir?
actually i sent this block out in may and i got it back last week so it was gone awhile i still have the other motor that was in there sitting on the ground deciding what i want to do with itWow. Very nice! A 3 week turnaround time on a block is awesome too.![]()
