into a 98 civic ex coupe.
okay so this is like MY first swap. (i'm having a friend of mine who has done over 100 B, K, and H series swaps helping me though .)
what i have so far is the following:
Engine/Transmission
- JDM Type R Block
- Golden Eagle block guard
- Eagle connecting rods (H-beam)
- JE 9:1 pistons with JE rings, block bored .020” over
- ARP main studs
- ARP head studs
- ARP rod bolts
- OEM water pump, oil pump, timing belt
- Cylinder head is all OEM, rebuilt with new valve seals 5k miles ago
- Magnecore sparkplug wires & MSD external coil
- USDM GSR transmission run only with Honda brand fluid
- Clutchmasters stage 3 clutch
- OEM flywheel
- Exhaust with catalytic converter and muffler for emissions
- axles (stock)
- shift linkage
- motor mounts
Turbo system:
- Garrett T3/T4 turbo
o .63 a/r exhaust
o 57 trim compressor
o Oil cooled
- All Aeroquip fittings (oil feed (-4) and return (-12) )
- All stainless fasteners
- Exhaust manifold bolts converted to studs
- Log style turbo manifold
o Port matched
o TIG-welded mild steel
o Symetrical wastegate exit
o Wastegate dumps to atmosphere (not piped into exhaust)
- In-car adjustable boost pressure (6psi and up)
- Resolution adjustable
-Varies how many psi 1 turn will add
- Mandrel bent charge piping, 2.25”
- Tube & fin intercooler measures 9” x 20” x 3”
o 2.5” outlet with re-welded 2.25” inlet
-Inlet relocated for charge pipe volume reduction
-“back door” setup
- 300zx blow off valve with recirculation
- 3” mandrel bent intake
- Genuine K&N air filter
- 3” into 2.5” downpipe, stud-type connection to turbine
o Downpipe has 3” dump with block-off plate
o 2.5” section goes under engine to connect with exhaust for emissions
- RC 550cc injectors
Tuning
- Uberdata ecu with OBD-II to OBD-I conversion harness
- 3 Chips
- Several different tunes including one to pass emissions
- Moates.net chip burner with usb cord
- Software for burner
Now then. Is there anything else anyone can think of that i would need to complete this swap, or any advice for me before i start it?
If anyone wants me to post pictures of my progress i will. I'm probably gonna start around thursday or friday.
Engine/Transmission
- JDM Type R Block
- ARP main studs
- ARP head studs
- ARP rod bolts
- OEM flywheel
- axles (stock)
- shift linkage
- motor mounts
Turbo system:
o .63 a/r exhaust
o Oil cooled
o Port matched
-“back door” setup
Tuning
- 3 Chips
