The defrost, a/c, and re-circulation buttons don't work or light up? How do I fix this? It slowly went from the defrost to a/c & re-circulation not working.
Any leaks in your car? Maybe something is leaking into the climate control? Have you taken the climate control out/moved it around recently? Perhaps the wires are just getting old, or the connections are shot?
I pulled the centre storage console and removed the dash below, low and behold, the re-circ, a/c, and defrost cluster cable was unplugged? It seems as though someone was in there "prior owner" and disconnected it and did not connect it back properly. Good work AHH VTEC ***** stars.
Onto the next problem
When I accelerate the parking brake light comes on. Only happens when I accelerate, and then goes off shortly afterward. More in the cold than when warm. Is it a defective park brake sensor or the park brake adjusted too high/low?
