b16a2 into a auto civic
  • Thread starter Thread starter aaronl
  • Replies Replies 4
  • Views Views 1K
aaronl
HI well heres the deal ive been doing some research on swapin in a b16a2 into my 93 civic... Theres only one thing, it has the auto, i know you can swap them over just by getting shift links, clutch assembly, trans, and ecus. but id rather just drop in the auto and save time and MONEY..... i have noticed some of the b16 motors on ebay.com, i was wonderin if any one has ever got one from there and has had good luck with getting it to them and having all the parts.... I do plan on getting the engine this fall and beef up the internals over the winter and then swap it into my car in the summer.... some questions i have are, what will i need to swap in a b16a2 into a 93 honda civic...... like ecus, and other electrical equipment that go along with it to make it a successful swap.... any info would be great.....if you have any suggestions e-mail me at ronzie05@aol.com or talk to me on MSN or AIM....... thanx again
b16a2 is 0bd-2. That's a problem. You need to get a SIR II b16 (it's obd-1 like your car now). Don't buy from Ebay. Get the engine from someone like hmotorsports.com. Just my opinion but you should sell it and get a 5 speed.
go to torontojdm.com.im also looking to do the same things as you but in a 98 civic ex.torontojdm has a COMPLETE swap. it has everything you need.it also gives you a list of everything that comes with it.i think it cost around $1400 for everything and a rough quote for the install professionally is $1200.i got it from my mechanic. keeping it auto is a good idea because i dont matter how good you are at shifting you WILL NEVER outshift a manual
although if you decide to turbo it will lagg but if u are racing froma stand still then it will give your car a chance to hook the tires and get traction wich is what you want but if your are goin strret with a rolling start then just simply down shift to get the high rpms so the turbo will kick in.:cool:
This thread is from 2003, you idiot. Congratulations on resurrecting it from the dead for your first post here. Next time, check the dates before you hit the "reply" button...
