95b16coupe
Well-Known Member
When doing an HDR photo, why take 3 or 5 pictures when you can take 1 photo and use a computer with photoshop to under/over expose the photo? I'm trying to find some info online, but I can't get any answers.
but isnt' manually taking 5 photos with adjusting the range going to give me the same photos and using 1 photo and adjusting 4 more versions of it? then i can combine them to make an hdr photo. i wouldn't have to worry about motion in the picture or using a tripod.over/underexposing doesnt give the same effect as an HDR photo..
i'm just lazy and want to take several photos instead of having to setup and take 5 manually, then move on.
In image processing, computer graphics, and photography, high dynamic range imaging (HDRI or just HDR) is a set of techniques that allows a greater dynamic range of luminances between light and dark areas of a scene than normal digital imaging techniques. The intention of HDRI is to accurately represent the wide range of intensity levels found in real scenes ranging from direct sunlight to shadows.
High dynamic range imaging was originally developed in the 1930s and 1940s by Charles Wyckoff. Wyckoff's detailed pictures of nuclear explosions appeared on the cover of Life magazine in the mid 1940s. The process of tone mapping together with bracketed exposures of normal digital images, giving the end result a high, often exaggerated dynamic range, was first reported in 1993[1], and resulted in a mathematical theory of differently exposed pictures of the same subject matter that was published in 1995[2]. In 1997 this technique of combining several differently exposed images to produce a single HDR image was presented to the computer graphics community by Paul Debevec.
This method was developed to produce a high dynamic range image from a set of photographs taken with a range of exposures. With the rising popularity of digital cameras and easy-to-use desktop software, the term HDR is now popularly used[3] to refer to this process. This composite technique is different from (and may be of lesser or greater quality than) the production of an image from a single exposure of a sensor that has a native high dynamic range. Tone mapping is also used to display HDR images on devices with a low native dynamic range, such as a computer screen.
i see.
since the photo may be too dark to begin with, you can't really brighten it up because there is no data. but if it's overexposed, you will have too much "white" and wont have any data.
so unless you can take a miraculously perfect picture, you wont be able to hdr one photo.
it helps to be good with photoshop. it's not just taking 9 pictures and layering them. that guy is definitely a professional.that 9 photo one makes me wanna try one of those
it only does part of it. it just layers it for you. ideally, you would adjust the lighting and color of each exposure, then layer it. or you would want to layer it, then adjust the colors manually.photomatix does it for you..
