No you dont run any oil lines, there is a oil jet plug in the block under the head you remove the plug so the v-tec head gets the oil pressure.Parts for the mini me are a v-tec head, odb-1 jumper harness, and odb1 dizzy and a p28 ecu also a v-tec sub harness make the job way easier. I just put a Z6 head on a SOHC ZC and it runs way better worth it i think for the money.
