GlassHeadlights
West West Yall
After all of this I'm concidering just paying the damn $350 and get it done professionally.
That is true but if I be patent and figure out exactly where I want to go with my car, I/H/E, cam, ect, I can just get one tune and be good to go.That's also a good option.
Think, "you can tune a man's car and it's good for now, or you can teach a man to tune and he'll make it good forever".
That also is true, all the money I've put into my car has been made by selling EF parts.If you think business, and you learn well, you can recoop the cost of parts by tuning other people's hondas .
Well the guy I bought my ECU off of put a basemap on it already so I kust have to tune it.Like 'boostin' said, you will have to burn a chip. Unless however you want to rely on your laptop to keep your car running lol. Windows is not stable enough for that (to me). But you can tune and datalog with the moates ostrich 2.0 system. Once you dial in your tune, you then want to save the tuning settings in a file on your PC, then burn a chip. Otherwise those settings dont stick in your ecu, and the emulation would always need to be running. Hopefully you get what i'm saying.
The LC1 is just a wideband controller like the one from PLX devices. Pick either, but your tuner may already have a wideband o2 setup and can save you some money.
I am aware of that.A basemap is only intended to be a logical starting point for the tuner. It's not at all meant to be driven on. Just so you know.
I have all of the maps already.PGMFI has/had stock maps for all motors. Their website hardly works anymore. But the .bin files are still out there.
I'm still a bit confused on the Ostrich and Hulog/Hondalog things.
What does the Ostrich do?
The Hulog/Hondalog connects a laptop to the ECU for real time tuning right?
I only have Crome not Crome Pro. Moates.net says just Crome will do the job though.
I also appreceate all the help thank you guys!!
... if you want to blow up.....you are at. you want to tune for 14.7 to 1 air/fuel ratio through your entire rpm range.
all motor should be in the upper 12's/low 13's under full load.
boost, high 11's, low 12's.
After I buy a Ostrich, Hulog, chip burner it will probably come to over $350 so I'll probably do the right thing and get it professionally done.
Well I found a local guy that will do it for much cheaper and I'm sure he would change my tune for cheap if need be.
Will do.Exellent , give us numbers when you get it done
Thank you.good luck with everything !^_^
