bjoebright14
thanks i didnt think so but somebody told me you did how do i give you more rep power?
does the raditor fans have to be hooked up for the engine to turn over?
and unless you are racing, i highly advise against this.A 91 crx does not require the fans to be hooked up to run. In fact I took mine out to make a few extra HP. The downfall is I can only run around for about 15 minutes at a time during the summer. It was well worth the extra time it took me to remove them.
I hope to remove the radiator later this summer casue when it gets warmer outside I won't need the antifreeze since the temps will be over freezing. I am thinking maybe April, just depends on the weather. With no fans or radiator I could probably get a extra 3hp to the flywheel that will get me the edge when I race.
Since I dont use the fans I just cut the harness and Ebay'd the connectors. I got enough saved up now to get a couple of stickers that will speed me up a bit.
Good luck.
Ok, no shit. Look man I'm asking what the specific engine is; D15, D16, B16, B17, B18, B20, H22, H23, K20, K24 etc.
i build most of the block cus it had a hole bout the size of fist
cus the kid used it 2 race and didnt dupble shift
i saw that yesterday actually, was waiting for someone to notice... when i first came into this thread i must have missed it.read his first post.. he wants a b16...
what exhaust is the best i want it real loud but still sound good any suggestions?
