ok, since my TPS on the dpfi is failing I figured why buy a new one when I have almost all the bits to update the intake.
I think I have all the parts.
I'm trying to figure out why the mpfi manifold I have looks different than most of the pics I've seen from a google search.
So I have
P28, (chipped need a base map for a PM6)
Resistor box
Intake w/ TB
Injectors
fuel rail with fuel line and banjo fitting
Distributor
A wiring harness (might need some other connectors for the injectors etc, as the harness has been butchered)
MSD ingnition coil, cap & rotor. (would need an MSD 6 or MSD 7)
I would need an intake manifold gasket, probably replace the PCV, and TB gasket.
Also it looks like a sensor is missing. Can anyone help identify this intake ?
Casting markings on intake
underside of intake
Thanks in advance
So I have
Resistor box
Intake w/ TB
Injectors
Distributor
underside of intake
Thanks in advance
