stevennn09
so i finally finished my swap and drove it for the first time today. theres a couple things wrong. first off the kid that i got the motor from capped off the coolant line that goes to the air intake with a screw and a clamp, also i got a broken fitv on my throttle body he said it would be ok if i just bypassed it so i just connected the lines that go to it together. my car is idling around 1500 rpms. also if i drive it around the block it will read that it's a little above the halfway mark on the temp gauge which im findind that to be extremely hard to beilve. also im getting code 8..which is tdc and also my tach is super messed up. make a converion harness obd1 1 obd2 for the dizzy...do you think that if i messed theese up it would cause both symptoms? sorry to sound like a noob im really not but im totallly stumped and i've been searching allll day and havent found anything out.. please help me!! i want my car to be noraml
also somehow i just noticed that i dont have a bleeder valve and there is no threads where it's supposed to go plus im not leaking coolaant from there.
