GlassHeadlights
West West Yall
I think I've decided to rebuild my D16A6/D16Z6 Mini-Me. Its burning oil and both the head and block have high miles.
So for the D16A6 block I was just thinking of...
~Honing, if necessary
~Decking, if necessary
~Rings, OEM or aftermarket?
~Bearings, I heard I should buy OEM because of a teflon coating or something
~I already did main seals and oil pan gasket, so gasket wise in the block its as tight as a drum
Then onto the D16Z6 head...
~Valve seals, OEM or aftermarket?
~Valve grind?
~Decking if necessary?
Anything else I should do?
The machining I can not do but all of the assembaly I can do...I've done it before.
~Valve grind?
