34diesel34
Import Tuner
I'm STUCK in the middle of doing a B16a swap in my 91 crx si. The car is jacked up with the engine still on the engine lift hanging in my engine bay with only one side mounted up
. It's the 2nd gen OBD1 B16a. I'm only able to get the right side (transmission mount) bolted up in the car. I can't get the rear mounting bracket in and bolted up. There's not enough room. If I put the rear bracket on 1st then the transmission mount will not line up.I'm using the rear mounting bracket off of a 95 GSR. I'm thinking that this rear mounting bracket will not work in a crx
Please help if you have the answers to my problems.
