Give it 30 minutes to be safe. Temp has to be perfect.
between coats, or the booth?
Between coats. Are you doing 2 or 3?
Clearcoat should be laid fairly heavy. Check the psi on your gun. I assume you followed the mixing instructions and used good products? 3 coats should have been enough.
fucking rain has been horrible. ive been trying to strip/paint/clear some calipers but i cant with all this rain.
my back yard is like a swamp.
