Wow. Definitely Hype R. I'd get a used crank balanced anyway.
Wonder what the cost repair vs. balanced gsr crank would be? Shit, should I just snag an LS crank and rods instead? lolWow. Definitely Hype R. I'd get a used crank balanced anyway.
Thanks man! Yes, the car felt pretty good. I've made major changes to the suspension. Weird driving with no front sway bar though, you can tell. Not sure if I like it or not yet; need more seat time with it like this.nice man...looked like your car rotated really well! second shortest wheel base right?
taking out the pistons/rods and oil jet for you as we speak.
lolGet the LS crank.![]()
Thanks, typically they grid us based on our previous best laptime. That session I was late so had to start at the very end. In TT we go all the way to turn 11 bunched up then start taking off. That way you really get a lot of open track the entire session.nice work getting through that trafficmust feel nice getting the track wide open in front of you.
looks like you almost didnt have enough to pass that miata at about 6:30, sounded like you lifted for a split second, then got back on it to pass. unless im just a noob and was hearing things lol.
Found a GSR crank for $100. Think I should just buy the GSR crank and not bother trying to repair my crank? My #4 rod journal does have a burn mark and feels a little rough (by fingernail)
The block I would send in complete and have them balance and blueprint the whole thing at this point. You will be going with mis-matched rods, a different crank, etc so there are several things potentially that ould go wrong. Also dont order new bearings yet until they mic everything and tell you what sizes are needed.The rings you could re-use but you shouldnt technically and probably should just replace since they arent too expensive "I know it sucks I had the same deal with my motor".
This is just my opinion.
