primeredseol
I have a 92 si hb with an H22a swap in it. I used the USDM intake manifold with the EGR and all. (i'm trying to BAR the motor in california.)
So i finally got finished rebuilding the motor, installed it and finished up the wiring. Heres where i'm having troubles; The motor was running very rough, so i took out the spark plugs. Cylinders 1 and 4 were dirty and 2 and 3 were spotless after about 20 minutes or less of idling. My buddy and i began trouble shooting and came to the conclusion that the injectors arent actuating for some unknown reason. I know its not spark because i tried 2 different distributors, 2 different sets of spark plug wires, and pulled the wires out while the engine was on and you can hear cylinders 2 and 3 arcing in the galleys. I thought it might be the injectors, so we tested them all and they show 4.3ohms. So we then tested the connectors for the injectors. One side of the plug on each injector clip reads 12.18 volts, while the other side reads 0.01 volts. All readings were taken with the engine off and ignition turned to the ON position. Since i did all the harness wiring myself, i figured i might have mis-wired injectors 2 and 3, so i swapped the injector clips but had no success getting cylinders 2 and 3 to fire. I even swapped out ECUs and still am having no luck getting cylinders 2 and 3 to fire. Any suggestions or ideas of what my issue could be?
any help would be greatly appreciated.
