Wassup everyone I got a 92 civic eg hatch back wit a d16zc sohc v tec im swapping out for a 92 95 b16a and I would like to kno wat I will need . i have motor.and trans but I think ill need axles and a shift linkage and half shaft and ecu so my question is is this all I need . What year and make and model should I get the doner parts from thanks
dont just jump in my thread lmao anyways matt if i get everything for turbo setup can i just use my stock ecu and tune it with chrome its a stock ls motor only looking to run about 10lbs of boost lmk thanks
Are you the kind of person that when they are at a party just jumps into the middle of a crowd of people you don't know, and starts telling some completely off the wall story?
Correct. OBD2>OBD1 harness, and you'll need to have someone chip your ECU. Basically enable it to have a different fuel map put on it other than the stock map.
