Quoted post[/post]]
what is evertthing i need 2 swap a b20b into my eg?i need to know everything even the little things!thanks
[/b]
I'm sure it's been covered 3,534,234,233 times before, but I'm in the process of doing one and will gladly help you out.
What I've done is purchased a wrecked CR-V and took the engine+drivetrain+wiring harness from both cars out and swap them. If you want to use the AWD tranny (like I did) you will need a tranny custom fab'd mount. Otherwise you can go Hasport or Place Racing. Bottom line, make sure you have everything from the donor car and be prepared to do some electrical wiring...
The car drives great. This engine got so much torque I can start it in 3rd from a dead stop and drive it around town like an automatic. Passing in 4th or 5th is a no-brainer, no need to downshift for any reason.
