"miles per gallon of gas "
  • Thread starter Thread starter gcoloma
  • Replies Replies 21
  • Views Views 4K
gcoloma
Hello!
another newbies in crx I'm planing to buy one a stick shift crx.
I've been told crx hf will run 50 miles per gallon is this true? and what year has more miles/:) gallon of gas?
gee I saw on the adds stick shift crx 1985 si 35miles per gallon and 40-45 crx hf.
and anothe one has oil leak on the spark plug housing holes is this normal ?
d15. look for rust on the underbody. ask when the timing belt was last changed. as long as it's been serviced regularly you should be good. mine's pushing 190,000 and still runs strong.
I'm in l. A is there any online or classified ads for sale ?
recycler and craigslists?
what to look for when buying this type of car?Stock
and the engine code is this a b16?t.y.
ok.. and your point is.. i'm just saying, with my b16 i get better than 30 MPG.. so, an HF will obviously have higher since its the fuel efficient model..
so how does a d15 looks like Picture pls. very well apreciated .
it looks like any other single cam. you have to look down by the manifold theres the engine code stamped on the block(right by where the tranny and engine meet)
62 HP stock. 90 lb.-ft. of torque helps but you're looking at 0to60 over 10 secs.
