try hydroxycut hardcore. i have a bottle of it and it works. its a liquid cap and i really feel it work in about 30 min after i take it.
yeah, i failed yesterday. I ate like shit.... and ate a lot tooCutting carbs doesn't have to be torture. Just pick them better and eat a smaller serving than normal. Replace the carbs you take out with an extra portion of lean meat.
+1 for the bowflex idea. They work well for not having much space. I want one too.
Wow, I haven't been to this board in a decade.
Anyway-
Brian, I'm in the same boat as you. Basically the exact same build also...260lb and 6'2. However anyone who looks at me thinks im much lighter. big boned i guess
I'd also like to lose about 30 lbs before next summer. id be toned at that weight. i dont need to get big at all, just need to drop the gut.
im assuming you have done a shit load of research on the proper methods for this. care to share with me the details? proper diet techniques, what to do for excersize and how long, the best supplements?....and more importantly- what NOT to do?
the info about drinking cold water is good- im gonna try to down a gallon per day.
thanks
that product is a little different than ghb
Somatomax â„¢ Directions:Take one (1) heaping scoop of Somatomax with water or beverage 30 minutes prior to bedtime. Note First time user use 1/2 scoop.
Warning: Do not operate heavy equipment when using this product. Somatomax may cause drowsiness. Do not consume this product with alcohol as it may cause side effects. Excessive serving amounts may result in dizziness, nausea, euphoria and diarrhea.
That's a bit too much water on a daily basis unless you're replacing what you're sweating out. Once your urine is clear you're fully hydrated. If you want something that will fill you up, get meal replacement shakes and drink one inbetween meals.
You're making it too much of a chore. How many meals are you eating a day? Six small meals a day is a good way to go.
what kind of meal replacement shakes are you talking about? where can you find these?
