motor prep questions
  • Thread starter Thread starter 94_gs-r
  • Replies Replies 8
  • Views Views 1K
94_gs-r
can you say 260 whp N/A??
im taking the motor out of my integra gsr, are there steps i need to take and shit to plug or do i just take everything apart and pull it out. i have all the bolt on stuff out and the drive axles out. what steps should i take?
so there are steps then... damn. already pulled most the stuff only thing i havent done is depressurise the fuel line
you dont need to depressurise anything....
Just take the damn thing off... nothing's gonna' happen.
dont forget the heater hoses in the back, and the o2 sensor(s)
I always seem to forget to take those out and end up fucking them up.
good luck!
true to marking, are you going to give it to me when you get it out?
there isn't anythign special just make dure you rememrber everything when you put it back in. Do the engine mounts last, obviously.
haha almost tried to pull it with shift linkage
on the intake, all of the vacume lines are those needed or are they just for the butterfly valves? im removing the butterfly valves
ac has been off for months
reason i ask about the cacume lines is because they go to the butterflies dont they?
