daveholiday
Do work
I know I realized that I was doing it wrong, thats why I kept getting super low compressions, and when I realized I was doing it wrong, I did it right and now I'm getting the right compression estimates. z6=9.95:1 and y8=10.3:1
that valve cover looks just like the one that i did..
https://hondaswap.com/general-tech-articles/how-paint-valve-cover-86106/
Might want to set the crank and cam to TDC (top dead center) before pulling the timing belt off. I suppose it doesn't matter as long as they don't get moved at all before the new timing belt goes on. You did get a new timing belt and water pump right?
Yea the a6 distributor bolts right up to the y8 head
Im doing this swap also here pretty soon. btw did you get a y8 head stud for the bolt nearest the vtec solenoid.
Also you'll need an adjustable cam gear, you may or may not know that. new headgasket for the y8 head. timing belt off a d15b7 (1992-1995 honda civic DX/LX)
Because if i recall the y8 head sits slightly higher then the a6 head when mounted on the block. So for one the stock belt will not work its too short. also you need an adjustable cam gear because you need to advance cam timing 4.5 degrees to compensate for the slightly higher head. if you dont get an adjustable cam gear you wont be able to advance the timing enough and it will run like butt
Yup, motor mount and crank pulley. Have fun![]()
I used a 6' breaker bar. Might be trickier with the engine still in the car. It's just the one bolt holding the crank pulley on. Makes a terrible noise like your breaking something when it comes loose.and I just noticed this, how are you supposed to take the crank pulley off? I haven't looked at it more because I havent been that far yet, are there multiple bolts or something holding it?
