efhondakid
My name is Byron.
Oh and I wouldnt recomend taking the plug wires off the dizzy, it will make your life easier to just leave them on the cap. Just take the three phillips screws loose and move the cap with the wires still on it out of your way. You may confuse the part your after with the yellow piece from the diagram (which is the ignition coil), there will be six phillips screws holding it down, (one is covered by some wires.) Once you get coil off the ICM will be off to the side closest to the firewall.
