ok, i have a 1990 civic dx already converted to mpfi with a blown up d15b in it, i really wanna go turbo with some pretty good numbers so im thinking b16a vtec, question is what needs to be done, what year b16a do i look for, do i have to replace the hubs, or just juse 90-91 integra axles, i know i need a motor mount kit, what about shift linkage, can i modify mine or is there a year car that i can use them off of, will the dx wiring harness work? and what about ecu, use a p28 and just wire in vtec, will i have enough room for a turbo set-up,
i was thinking about dropping in a dohc zc (130 hp stock) but that swap just seemed to easy, rather drop in a slightly built b16a (around 160 hp stock) boost around 8-10 psi and murder everything around town
