2000 ek swap NEED HELP
Okaay so I need a little help I have a 2000 ek I just bought and it’s giving me problems it has a swapped d16y8 vtec motor with a automatic transmission converted to manual. Not sure what computer honestly... it’s just a Frankenstein... I have a bad idling issue and I’ve swapped out the intake manifold and fuel injectors, hoses etc. I still have a vacuum leak and the idling problem I’m new to all this swap stuff so I need some help
I had the leaks when I got the car and I’ve already fixed em but nothing I changed the fuel injectors, iacv, the whole intake module ,fuel rod all that stuff I’ve changed but I still can’t get it
Briansol
Admins
Admin
VIP
pull the codes. it will help point you in the right direction?
