lilredrocket08
I am going to turbo my 94 ls coupe and i already have a garret 60 trim turbo, is that way too big or will it work fine if i put all new internals n build the head a lil bit
thanks John
thanks John
For the goals idk yet prolly somewhere is the high 200's is fine. i have a turbocharged nissan 240sx n this was the turbo i was going to use. For the budget im just going to spend along the way but pretty much can do anything
Hp goals i would be fine as long as its in the high 200's but if i can do more i will. I currently own a turbocharged 240sx with this turbo in it. I was going to use it if i could but i didnt know if there would be too much turbo lag. Budget pretty much anything i can do
what do you think i should do like run it at what psi and about how much power will it make
i had my buddy tune my 240sx and i ran a 12.2 on 15 psi on a stock motor
