98 B18C1 into a 95 civic
Once again almost certian that you'd use the rear mount(more of a bracket,due to lack of rubber) from the GSR.The 99-00 si b16a2 apparently has to use a integras when installed into that chassis.You will need to use the GSR's mounts.
Originally posted by 92b16vx@Dec 23 2002, 03:35 PM
...what is the swapping part like from 20-17 what is that all about ?
I'm not sure what you mean 20-17
thats obd 2 motor -> obd 1 car ONLY. if you get a 94 or 95 gsr motor for a 92-95 civic, you wont have to do this.
if you get a 96+ gsr motor, and put it in a 96+ civic, you wont have to do this.
basically, the IAB is wired 'backwards' when the switched obd, so you gotta swap em
yup- use any integra mounts (they shoudl come with your motor swap anyway) from 94-01. they will bolt right into a 5th gen chassis.
the EASIEST swap is to get the same year motor obd for the same year odb chassis
