NissanNiNjA2nd
run 17lbs in the tires, heat them up to 170* and dump the clutch while feathering the throttle around 4k. It'll hook.
Also, something is VERY screwed in that car if it is only trapping 89mph. You should be up in the high 90s with all of the weight you have removed.... unless there is a 400lb sub box in the back.
