Zoarette-racing
Banned
Wasup, I was wondering what to do to make more power out of my B16. I might build an ls/vtech or b20
I dont know what to do or should i keep my 16 and raise the compression cause its a 1.6. What about cams i heard only 16 whp. What should I do for I/H/E (intake,header,exhuast) and if I build a b20 will my axel be ok
THANKS, Zoarette racing team
 and I doubt cams are going to get you 16 whp, although I wouldnt doubt the manufacturer told you that. If you really want to make your car faster turbo it, or send your block in to be bored out, and maybe get some different rods to increase your stroke. That would get you to a 2.0l. If you have the money I would do a turbo kit as well as that. But turbo is expensive. To do it right you are looking at around $5k including tuning, to do it cheaply (low power gains, like 75 hp or so) maybe $3k, and for massive power gains, $15k or more. All about what you want out of it, and you only get out what you put in. Look around on the board there is alot to learn here, and then if there is something you can't find ask questions. But do look first chances are its already been asked.
  Vtech
 Vtech
