Ok I put a B16A1 in my 94 civic coupe...it was running really well for 1 week straight. Then, all of a sudden the car started to bog out at any rpm...when i tried to give it gas it would not rev...it would bog out more...then my starter went out and I could not even crank it over. I had to push start it and when i did i t would bog out and I could not drive it...sometimes it would come back to normal idle but when you tried to give it gas to drive away it would sputter then bog out. Today I got my starter new. They fully tested it before I left and works fine. I changed the cap and rotor and put an after market coil with msd cap. Also changed the plugs and wires. I am getting fuel and pulse. I did a cel check and no check engine...but my car won't turn over at all...it will not crank...battery is good...anyone know what this could be?
