Hi, I recently bought a em1 with a b16 jdm swap in it.
When I cold start the car, it idles at 2k (anormal...)
After that, choke isn't coming off, I can roll it for 1 hour, motor will be hot, and it'll still idle at 2k...
BUT, when I turn off the car and turn it on again, idle is dropping at is normal rev.
I only have to turn the key to accesory position and return it to ON again, motor's idle will be okay..
What could that be? I got a O2 sensor problem, a EVAP control vaccumm problem and a Knock sensor that needs to be changed... But I don't think that could affect my idle?
Could it be a electronic problem? It revs at 2k until i turn off the motor and turn it on again... I tried to clean my idle air valve control...didn't do anything.
Thanks guys
Thanks guys
