best mini me setup?
  • Thread starter Thread starter CRX2NR18
  • Replies Replies 5
  • Views Views 3K
CRX2NR18
i am looking for the biggest TB for a D series, and intake mani that will wire up obd0 , not sure if anything if different on intake mani's. and also best distributor. I heard a z6 TB and y8 intake mani is the best for flow, what do u think?
when i used to have a 93 civic dx i had a 1990 ls throttle body bolted right up and was definetly a few mm larger. When i went to put my AEM back on i had to stretch the crap out of the rubber coupling to make it fit on the new throttle body
pimpy OEM component mini-me setup:
D16A6/D16Z6 block
1.6L crank
LS rods, machined to slim
PDN 98-01 GX pistons
3 layer OEM headgasket - A6
ARP/AEBS headstuds
D16Z6 head
D16Y8 cam
D16Y8 5-spd intake manifold
62mm ITR TB
D16A6/D16Z6 block
1.6L crank
ARP/AEBS headstuds
D16Z6 head
D16Y8 cam
62mm ITR TB
damn dude you know the good secrets
i have heard that the ls rods are the strongest oem on this set up with the zc pistons
also i have found thats throttle bodies are compatable with there obd's
for ex. if i have a 95 ex inatke mani...i can put a obd1 b-16 tb on it and it fits and works
