Broken vaccum fitting
  • Thread starter Thread starter C-Bye
  • Views Views 585
C-Bye
The vaccum line directly above the intake on the tb is broken. Is this a problem. I tried an ez out, broke inside, it is plugged up really good now. is this going to cause problems?
Quoted post[/post]]
Um shouldnt you put the vacuum line in there?
Go to autozone, but a fitting and put it in there, wrong vacuum lines = horrible gas mileage.
There are two vacuum line fittings one is offset towards the front of the tb then one dirrectly on top. the one on top? I was told it goes to the charcoal canister? Can it be plugged?
I tried to take it out with an ez out, it broke inside, thought about drilling but metal shavings don't sound good in the intake, replace the throttlebody? It came broke when I bought it, call them? If it is an ez fix I don't want to go through that B.S.
