cam replacement
yellow88crx
My cam shafts on my b16 need replaced. if I was to replace them with b18c cams, would this be anything of a power gain, and would anything else need replaced?
yes gsr cams will be a power gain... not huge, but a little. you dont have to change anything else to use b18c1 (gsr) cams. however if you get type r (b18c5 or b16b) cams you should upgrade the valve springs as well.
btw... i have some b16a cams if need them.
how much do you want for them, and do they still have the cam gears attached? mine were screwed up as well... good lesson here, do not use obx parts. :-)
