D Series To B16a
  • Thread starter Thread starter civicB16A
  • Replies Replies 6
  • Views Views 920
civicB16A
i have a 92 civic HB dx with a d series. i threw a rod right thru the block a couple of days ago, and i have a b16a ready to go in. yet, this is my first honda, and even though im good with engines i still need some help. is there anywhere i can go for step by step instructions?
thanks,
matt
If you have a 92-95 B16A from a JDM civic or B16A3 94-95 delsol,you can use the manual from your car to remove the D and install the new B.As long as you have the motor,tranny,shiftlinkage,mounts and ECU,it is a pull the old one drop in the new one deal.You will need to run the vtec wires and knock,but as far as swapping the motor it is 1,2,3.
you will need motormounts, 93 integra axles, you will have to wire up vtec, and shift linkage
92 civics are pre-wired for VTEC ... so there is no wiring needed
and if you use a chipped P28 to run it it wont look for a knock sensor
thats about all there is to it
if you tune it right and use good gas... no
if not then yes
all a knock sensor does is detect predetination and retards the timing to attempt to get rid of it
