ecu problem
90_accord_22657
battery hooked up backwards everything works fine but i think their is no fuel getting into the engine the fuel pump is working fine possible ecu problem? or main relay or maby a fry in the wiring harness???
I would check the fp itself(take out of tank and remove pump,conect pos and neg up)make sure it is work...
next swap your main fuel relay out for a new one...
check all the lines going to the tank and engine...
hope this help. :)
