Finally back in the garage....
  • Thread starter Thread starter Airjockie
  • Replies Replies 427
  • Views Views 79K
What are you running im assuming those looked like Brembo blanks but what was the pad
something like this with red centers...
or these....
quik poll....
studs look fine.
greenstuffs are horrible for competition. i've cracked a set of pads... then again my calipers/rotors/pads are much bigger.
.................bahahahahhaha
(yes i know you were kidding)
Some new parts...
New rebuilt steering rack...
Sandblasted and painted up stock crossmember...
Bushing that I had to grind down to fill the hole on crossmember for the new rear engine motor mount..
Everything going back together with new lower control arm bushings, new steering rod ends, new lower control arms and ball joints, motor mount for a B series engine, the 31mm torsion bars, sandblasted and painted torsion bar tubes, all hardware cleaned up, inspected, and replaced as necessary...
they just don't have tires right now...
They are pictured with P255/40ZR-13 Hoosier A DOT racing radials
and I may be buying the 13x10 panasports...:ph34r:
great job so far!!!
the A6s are the stickiest tires i have ever competed on so far. i would even get another set too.
