i've killed myself a few times that way..
Apparently there's an achievement/trophy for doing it to an enemy...
my worst way of death; i got turned around in the upper building level, ran out the wrong window and plummeted to my demise.
How many hours have you played?
i think you should be saying days.. lol
I have close to 12 days into it, and thats out of 3 months and 12 days.im wanting to kill someone by placing a 3rd claymore out causing it to blow the first up killing someone and see if that gives me anything.
So I was playing the other day, and somehow I just died. I wasn't quite sure how it happened. On the Kill Cam I watched myself running and then a care package dropped right on my head, lol...
let me guess.. Quarry?
getting the kill cam on a enemy with a care package would be cool
Learning the dynamics of each map will lead you to have a much better experince. On most maps there are always hot spots where most of the action goes down. Once you get that down you can naviagate around campers and the like.
That depends. On COD4, if you get your uav, you can find them easier, get two more kills and get two more with your airstrike. Once you get your chopper kill yourself or wait to get killed then call in your chopper. Then it'll do the work for you. I've literally had games on COD4 where I got my first 5 kills then never bothered to fire my gun again because the chopper got me another chopper.
This is why I like MW2 SO MUCH more... different rewards, and the killstreak you use to get kills after you respawn doesn't count toward your new killstreak. So in essence, YOU have to get the kills to get the streaks. The choppers won't get them for you. Also the fact that Cold Blooded negates any air support makes it so much nicer.
hey brutal, you might actually benefit from the "noob tube". try adding a grenade launche to your guns. use it to keep a safe distance. then switch to guns after you use both shots. my kill/death ratio improved a lot when i started using it.
