Okay, I just thought up a great analogy to explain what I am talking about.
Okay take the freaking Hoover Dam for example. and compare it to a turbo system. The colorado river (i think) is the normal sized turbo. The turbines at the bottom of the dam are the engine, and can only let so much water through. The amount of water they can let through is based strictly on the water pressure, because they size of the openings do not change. The higher the water is above the turbines, the more pressure is on the water that is flowing through them, so more water gets through...generating more power. Now if the water level gets too high, it flows through the spill ways and bypasses the dam all together.
Okay now that you have that all envisioned in your head. What would happen if you added the water content of the amazon river to the colorado river? (getting a turbo that is too big for the application) All that will happen, is that the water will come down and spill out of the water bypasses. It will not make the water flow any faster through the turbines, because the water level isnt raising due to the bypasses.
A turbo works exactly the same way.
You slap the optimum turbo on a gsr engine, set the wastegate to 5 psi, great, you are making tons of power without very much being wasted by being diverted by the waste gate. If you slap one big ass turbo on there, you still get the exact same amount of air getting into the engine (provided the smaller turbo was able to boost at the full psi at the redline) , because all of the excess created by the larger turbo is simply being re routed.
You can ONLY fit 500 cf/m into a GSR. A big fucking turbo will not change that. A small turbo will be able to move 500 cf/m at 5 psi. A big turbo will be able to move 500 cf/m at 25 psi. If your waste gate is working properly, your big turbo will NEVER exceed 500 cf/m at 5 psi. So what advantage do you have if you put a turbo capable of pushing 500 cf/m @ 25 psi if your waste gate is set at 5 psi. Well I guess if you consider LAG an advantage you could count that. The only time the larger turbo would be advantageous is if you set the waste gate above 5 psi. The larger turbo would be good all the way up until 25 psi on that specific GSR engine.
5 psi on a t888888889999399393939 is exactly the same as 5 psi on a t01 on a GSR as long as both turbos are able to push 500 cf/m @ 5 psi. You are no more likely to blow up the engine on the large if your waste gate works right.
Now guys get your shit together. This has gone far enough.
